RockCrawler.com Trail Gear releases Tacoma strut kits
Tacoma Front IFS 3” Strut Extension Lift
303065-1-KIT.webp Want to lift the front of your 2005-2014 Tacoma without the hassle? Our new Tacoma IFS Front 3” Strut Extension Lift is exactly what you need. This IFS Strut Extension Lift is a simple bolt-on kit, eliminating any need to disassemble your front struts. The strut extensions are constructed out of black anodized 6061-T6 aircraft grade billet aluminum and the mounting studs are made out of zinc-plated Class 12.9 alloy steel for superior strength. This kit was designed to give you a 3” lift in the front while keeping the stock suspension feel.
Note: We recommend you purchase and install a Diff Drop Kit (part #300705-1-KIT) when installing this kit on a 4WD Tacoma.
Tacoma Front IFS 3” Strut Extension Lift, 303065-1-KIT, $124.95
Tacoma Front & Rear Strut Extension Lift
303066-1-KIT.webp Want to lift the front and rear of your 2005-2014 Tacoma without the hassle? Our new Tacoma IFS Front & Rear 3” Strut Extension Lift is exactly what you need. This IFS Strut Extension Lift is a simple bolt-on kit, eliminating any need to disassemble your front struts. The strut extensions are constructed out of black anodized 6061-T6 aircraft grade billet aluminum and the mounting studs are made out of zinc-plated Class 12.9 alloy steel for superior strength. 2” rear add-a-leafs with anti-friction pads are also included. This kit was designed to give you a 3” lift in the front, level the truck, and eliminate the factory rake. Best of all, it keeps the stock suspension feel in the front suspension.
Tacoma Front & Rear 3” Strut Extension Lift, 303066-1-KIT, $135.45
Tacoma Complete Front & Rear 3” Strut Extension Lift
303067-1-KIT.webp Want to lift the front and rear of your 2005-2014 Tacoma without the hassle? Our new Tacoma IFS Complete Front & Rear 3” Strut Extension Lift is exactly what you need. This IFS Strut Extension Lift is a simple bolt-on kit, eliminating any need to disassemble your front struts. This kit includes strut extensions, a Tacoma diff drop kit, 2” rear add-a-leafs, and a driveline spacer kit. The strut extensions are constructed out of black anodized 6061-T6 aircraft grade billet aluminum and the mounting studs are made out of zinc-plated Class 12.9 alloy steel for superior strength. Our Tacoma/FJ Front Differential Drop Kit is made out of solid aircraft-grade 6061-T6 aluminum and zinc-plated Grade 8 hardware. The complete lift also includes our new Tacoma Driveline Spacer Kit. The Tacoma Driveline Spacer Kit is made out of 5/16” thick zinc-plated steel. Longer M10 mounting bolts are included in the driveline spacer kit. This kit was designed to give you a 3” lift in the front, level the truck, and eliminate the factory rake. Best of all, it keeps the stock suspension feel in the front suspension.
Tacoma Complete Front & Rear 3” Strut Extension Lift, 303067-1-KIT, $187.95
The post Trail Gear releases Tacoma strut kits appeared first on RockCrawler 4x4 and Offroad Magazine.
  1. Trail-Gear – New Product Releases!
  2. Trail-Gear Tacoma SAS Kits
  3. TRAIL-GEAR ADDS POWER STEERING PUMP WITH TACOMA SERPENTINE PULLEY KIT TO ROCK ASSAULT™ LINE
