RockCrawler.com Warn Industries Introduces Epic™ Winching Accessories
Built tough to live up to their name
Clackamas, OR (8/12/15) – Warn Industries, the global leader in winching products, is releasing a new high performance lineup: WARN® Epic™ Winching Accessories. Designed to complement the look of WARN winches, each top-of-the-line Epic accessory is carefully crafted to hold up under difficult winching situations. A multi-layered E-coat protects forged steel components from both corrosion and abrasion.
Epic™ Winch Hook
Forged from steel, the rugged WARN Epic Winch Hook not only holds strong, but also it stands up to wear and abrasion thanks to its E-coat finish. Its unique design even features a built-in beverage opener. Available in three sizes: For winches with capacities up to 5-, 10- or 18,000 pounds.
Epic™ Shackle
The double tough, forged steel WARN Epic Shackle lets users connect the looped ends of cables, straps, and snatch blocks. The threaded pin allows easy removal. Abrasion-resistant E-coat finish means this shackle will stand up to wear for the long run. Available in two sizes: for winches with capacities up to18,000 lbs., or a smaller size for up to 5,000 lb. capacity winches.
Epic™ Snatch Block
Armed with a durable, corrosion-resistant E-coat finish, the Epic Snatch Block helps off-roaders get more out of their winches. Under proper use, this multi-purpose snatch block can effectively double the pulling power of any winch or change its pulling direction, without damaging the rope. It also helps to reduce heat buildup and amp draw during recovery. Accepts both wire and synthetic winch rope. Buyers can choose from units rated to handle up to 5-, 12- or 18,000 pounds.
Epic™ Tree Trunk Protector
WARN designed the Epic Tree Trunk Protector rigging strap to anchor a winch rope to a tree, and then protect the trunk from damage during winching operations. What sets the Epic Tree Trunk Protector apart is the premium nylon strap with encased red warning marker to indicate damaged webbing, plus the end loops reinforced with E-coated ring connectors to minimize wear and abrasion. Three sizes are available: 4” x 8’ rated to 30,000 lbs.; 2″ x 8′ rated to 14,400 lbs.; and 1″ x 8′ rated to 7,200 lbs.
About Warn Industries
Warn Industries is the world’s most recognized brand in off-road products such as hub locks and vehicle recovery winches. The company designs, manufactures and markets a full line of off-road equipment and accessories that enhance the performance of four-wheel-drive and powersport vehicles. Warn Industries has employees in and around Portland, OR, Livonia, MI, and the Netherlands. www.WARN.com?utm_source=rss&utm_medium=rss
The post Warn Industries Introduces Epic™ Winching Accessories appeared first on RockCrawler 4x4 and Offroad Magazine.
  1. Warn Industries Introduces Epic™ Winching Accessories
  2. WARN INDUSTRIES TO UNVEIL NEW POWERPLANT 9.5 AND 12 ALONG WITH PREMIUM ACCESSORIES AT THE 2013 SEMA SHOW
  3. Wide-ranging WARN Industries New Product Lineup Led by Low-profile Ascent™ Full Size Truck Bumpers
