Centerforce® is proud to introduce this New Dual Friction clutch assembly for the 2000-2004 Nissan Xterra and 2004 Nissan Frontier with the supercharged 3.3L VG33ER Engine. This new clutch assembly replaces the stock pressure plate with a more reliable assembly with a higher holding capacity that is designed as a direct bolt in for perfect fit and function. Centerforce strives to provide the best products on the market at any performance level by using patented processes and constantly testing different materials and designs to find the best combination. This new application is now available as a Dual Friction® clutch assembly for use in high torque performance applications. The Dual Friction part number is DF633500 (Pressure Plate and Disc Included). Also available is the Centerforce II assembly as part number CFT633500 (Pressure Plate and Disc Included).| ITEM | TYPE | DESCRIPTION |
| CFT633500 | CENTERFORCE II CLUTCH PRESSURE PLATE AND DISC | 00-04, NISSAN, FRONTIER–XTERRA |
| DF633500 | DUAL FRICTION CLUTCH PRESSURE PLATE AND DISC | 00-04, NISSAN, FRONTIER–XTERRA |
A division of Midway Industries, Inc., Centerforce® is proud to be recognized as the leading manufacturer of performance clutch and pressure plate systems in the United States. Centerforce has over 1700 different non-asbestos clutch/pressure plate applications available to the automotive enthusiast. Continuous development and improvement of product offerings is reflected in the unique features of the Centerforce clutch line which is protected under nine (9) separate U.S. patents. With headquarters located in Prescott, Arizona, Midway Industries and Centerforce are proud to be a three-generation family owned business that’s committed to designing and manufacturing the highest quality and most innovative products available. Centerforce clutch systems are the performance enthusiast’s first choice and can be found on leading OEM and customized vehicles worldwide. For more information, contact Centerforce directly at 928/771-8422, go to www.centerforce.com or visit your local Centerforce dealer.
