Rough Country Unveils 4” Jeep ZJ Long Arm Suspension Kit
DYERSBURG, TENNESSEE— Rough Country Suspension Systems announces an exciting new addition to the family of Jeep ZJ Lift kits with the highly anticipated 4” Longarm X-Series package. Boasting some impressive features, the ZJ Longarm Kit is a comprehensive package including everything needed for a great suspension lift while maintaining the vehicle’s crucial center of gravity. The kit includes adjustable high-clearance X-Flex upper and lower control arms featuring the new, rebuildable X-Flex joints with Adjustable Retainer Rings that allow you to preload our Clevite bushings by compressing them prior to install. The kit also includes 4” coil springs, front adjustable track bar with drop bracket, ¼” thick steel crossmember and skid plate, sway bar disconnects, and much, much more. Outfitted with Rough Country’s Performance 2.2 shocks, this Longarm Lift Kit is a total solution comprised of top-notch components.
Rough Country’s X-Series line focuses on improving off-road handling and articulation while preventing binding and rear steer. This lift kit features high-clearance components with a front y-link and rear 4-link control arm design. This promotes extreme axle flex while keeping pinion angles optimized. Utilizing adjustable components, X-Series can also accommodate future modifications. This kit is capable of fitting a 32” tire or larger with some body/fender modification. The Rough Country ZJ Longarm X-Series Kit requires no welding to install and retails for $1499.95
Formed in early 1970’s, Rough Country Suspension® Products was a founder of the off-road industry and is one of the fastest growing manufacturers and marketers of lifted suspension packages and off-road accessories for 2wd and 4wd trucks and SUVs. Rough Country Suspension® Products is owned by Heckethorn Products® which boasts a rich history in the automotive aftermarket, including the invention of the first steering stabilizer for military Jeeps in the 1950s. Rough Country Suspension Products offers retailers, wholesalers, and consumers an opportunity to purchase easy to install off-road products the market is demanding.
CONTACT: Rough Country Suspension Products 1400 Morgan Rd. Dyersburg, TN 38024 800-222-7023 www.roughcountry.com/
