Twinsburg, Ohio – The Battery Analyzer from CTEK is the perfect testing solution for technicians as well as hobbyists and weekend mechanics. From cars to lawn mowers to snowmobiles, the Battery Analyzer can quickly test and diagnose all types of 12V lead-acid batteries including Wet, Maintenance Free, Ca/Ca, Gel and AGM.
With the CTEK Battery Analyzer you can quickly get to the source of battery problems in any vehicle. Connecting and testing is easy, with no need to disconnect or remove the battery from the vehicle prior to testing. Simply connect the battery clamps to the charging posts on the battery, select the battery type, and press the “test” button. The Battery Analyzer displays an easy-to-understand battery diagnosis which suggests a next course of action to remedy the issue, or if the battery needs to be replaced.
The CTEK Battery Analyzer is the perfect tool for technicians to ensure that all of the vehicles they service have a battery that is in good working order before it causes an unexpected problem. The patented technology incorporated into the CTEK Battery Analyzer protects both the user and the vehicle’s electronics from sparks, short circuits and reverse-polarity connections.
For more information about CTEK chargers and battery maintenance systems, phone 330-963-0981, email info@smartercharger.com, or visit www.smartercharger.com.
