For Sale: Idaho/ Coeurdalene / 2015 Jimmy’s Custom Built Podium LS3
We have a fully built 2015 Custom Built Jimmys Podium 2 Seat! This machine has every option possible! Full build sheet attached at bottom of thread! LS3 430hp! 40x15.50x17 Cooper STT Pro Matched with 17in DT1 wheels! Full PSC Steering , FYP concepts bronco body, full steel belly, full fox suspension, willwood brakes, dual exhaust, dual fans, upgraded LED lights, blinkers , THM 400 transmission, Atlas 2 transfer cases , spyder 9 axels, PRP seats, harnesses , 8k winch , and more.
No expense sparred on this build! Will handle anything you throw at it!
BUILD SHEET /
Costs over $135k now to build. Over $120k into this one!
BUILD SHEET FOR "CNC" BLOODLINE
$35,000 Step #.1-#2.-#3. 2-seat-Podium Bloodline Roller KIT
$35,000 Bloodline Roller KIT Podium series;
2.0 x .120 DOM ;
Main frame, Hood-line, all door bars, Belly, Lower front Frame rails, Roof over head "X"-ing, Top part of "X" in rear window, and outer rear belt line, "C" support to lower "B" Vertical support
1.75 x .120W DOM;
Lower rear frame, Inner Bed and rear shock support Vertical, front window down tubes, Vertical support tubes front window to front frame rails, Nose Verticals, winch fill and support tubes
1.5 x .120W DOM;
Front shock vertical support tubes, dual engine cross over tubes, Lower "B" support to belly (Seat "H" mounting), Seat tube
1" x .120W DOM;
Dash and center dash for floor layout
1.25x.120W DOM;
Engine Skid plate
Options Included;
Gen IV design
Turnkey Fill and Support tube Kit
This is all the fill and support tubes for shocks, seats, Gas tank, winch, etc
Bumpers
Single tube front Included
Single tube rear Included
"V" Doors
Mounts
Bloodline series Master Bracket kits-Standard Option's;
Tabs & Brackets- All Included in Standard kit
Motor mounts at center block, Head mount kit, Transmission adapter mount, Transfercase torque mount, Link mounts at chassis (.25 thick, for 3/4 bolt lower/upper), 1-piece steel Belly Base Mild steel, Hydraulic Valve Tab for under dash, Trans-shifter tabs, Resorvoir Tab, Seat Belt Tabs, Limit strap tabs, Tabs for all sheetmetal "Standard", Swaybar Double shear Tab's
Master Bracket Options and Add's;
#1.Belly
Steel belly 54"
$300 **Upgrade AR400
#2.link Mounts
Link mounts 1/4" for 1.25 lower and 3/4x7/8 upper
**Weld washer tabs
#3.Radiator Mounts/Cups or tray;
Front CBR
#4. Battery tray
Single Optima
#5. Motor mount
GM LS*/GEN III-IV Standard
#6. Transmission mount,
Atlas -Standard
#7. Transfercase Torque mount,
Atlas Standard
#8. Fuel Tray
16G
#9. Steering,
Standard
#10. Winch Mount,
Full drum,
Long Fairlead bracket
#12. Shock mounts,
Dual cross over tube Included in chassis
**Single shock
#13. SKID's
Engine Skid Plate with UHMW
#14, Accessories
Gusset Kit
Side Nerf Bars Pair (Includes Install Time) (skinny, Mid or wide)
Passenger Grab Handle w/grips
Tab Antenna
Engine head mount kit
Tow hooks each 4 corners
Add Attachment point for winch Tie Off point
**Add rear view Mirror
side mirrors
SUSPENSION Bracket kits;
4-link Standard Master Axle Bracket Kit-Large
Upper front link Towers Brackets w/weld washer Tab style, Bump stop landing pad's
Rear upper Towers for Jimmys Traditional mounting,
2-sets of lower link kits, Lower single shock tabs or dual, Weld washer tab style
Body
Front Clips Included's HOOD PIN KIT
STANDARD 1-piece Universal hood-
Included HOOD PIN KIT
Rear Clips
STANDARD Rear Fenders Aluminum w/Aluminum rear
BLOODLINE ROLLER FABRICATION
Turnkey Standard Master Fabrication
Chassis;
Place motor/trans/t-case (Includes weld in Motor mount and Transmission mount, place and weld Transfer case torque/support mount) weld belly and link mounts "Standard", weld in Fuel tray "Standard 16G", set and weld in winch mount, HYD steering mount "Standard", Radiator mount "Standrad", Seats and seat belts, Transmission shifter, Transmission cooler “Standard”, Power steering cooler "Standard", Place gauges, Mount Battery tray-single Firewall location, Power steering reservoir, Mounts for fuel pump and filters Standard, shock Reservoir mounts, Swaybar Double shear Tab's
all tabs to go Turnkey
INTERIOR;
All Floor work/Firewall work, Standard dash and center console, Fuel splash behind seats
EXTERIOR;
Front kickers, Doors, Roof Standard, Rear Aluminum fenders and Tail gate
Axles;
Place and weld in all Suspension link mounts, Place weld shock mounts "Standard", Mount front steering Ram, place limit strap tabs, place and weld in swaybar tabs
$4301 Step #.4 shocks
Shocks and Bumps
$1233 $616.50 X qty 2 FOX Factory Series Coilover w/res 2.5x14"
$1251 $625.50 x qty 2 FOX Factory Series Coilover w/res 2.5x16"
**w/DSC adjuster
$702 $175.50 x qty 4 FOX Factory Series Bump stop 2.0
$120 $30 x qty 4 FOX Factory Series Bump stop Mounting can
$600 Pac Springs 3.0 ID for 2.5 Coilover
$145 Shipping and Handling
$250 Limiting straps
set of 4, Includes quad straps, Tabs and Bolts, Fabrication to place and weld
$2,520 Step #.5 Suspension Parts
ROD END KITS W/SPACERS
$770 Large ROD END KIT
7/8 UPPER, 1.25 lower C-Molly Rod Ends, Stainless spacers and Washers
Link Material-Aluminum
$1,750 7075-Large LINKS
$1,906 STEP #6. Steering
Steering;
$1560 Steering – Dual Cylinder
PSC, full hyd kit, (TC/”P”) Pump, Steering VALVE (3.5 turns, other valves are available), COLUMN for Steering WHEEL), RESERVOIR (6” reservoir w/low pressure hoses), Hi-Pressure HOSES AND FITTINGS, DUAL 2.5 RAM, Small ENDS, END LINKS (Rod ends and dom tube),
$30 PSC steering wheel Disconnect splined
$88 Shipping and Handling
Steering accessories
STEERING WHEEL
$60 Lonacre 13" aluminum w/rubber grip
UPGRADE’s
$90 7075 Aluminum Steering Links, dual Ram
Step 5.B choice a cooler
Coolers
$78 Derale 18” log cooler
Includes 1.5 x .25 DOM tubing for steering ram
$1,400 Step #7. Fuel Hard Parts;
FUEL
$233 Fuel Cell– #260-116-NF Poly tank, No Foam
Jaz 16G race tank w/extra Injection fitting, NO FOAM
$78 shipping and Handling 16-22 Steel can tanks
$109 FAST FILL KIT
Fuel Pump Pick up kits;
$750 IN-TANK, Holley Hdra mat, 32G Alltech Baffle kit ($280)Hoses fittings and Install Labor
$230 Brake kit
wilwood dual master, 1” Bore , Fabricated Pedal (Longer ratio), qty (2) 2# residual Valves
$1,527 Step #7. Hard Parts & Accessories;
Seats
$700 PRP Premier with Drains and custom stitching
$95 SHIPPING
**PRP w/drain
$232 seat belts
PRP w/sewn in shoulder pads, 5-point with rear loop, BITD/KOH certified
$500 Rear storage Kit;
Igloo 18G cooler 8gallon storage, bottom tray mounting kit and install with pin style strap
$3,392 Step #9. Mechanical and Accessories
$700 DRIVE LINES
1350 2.125 X .188W DOM, W/spicer SPLINES "Balanced"
$20 DRIVE LINES U-Bolt kits
(Qty 4, spicer 1350-1410 u-bolt kits
$800 EXHAUST
dual, EXHAUST, CLAMPS, Dynomax BULLET MUFFLER
FABRICATION/INSTALL
$850 Jimmy's Sway bar 1.125 Active, 35 Spline
$900 WINCH
WARN M8000-s W/syn winch rope 100’ x 3/8
$122 Catch cans Race
1 quart Breather/ with filter; AN6 Inlet
1 pint mini breather w/filter, Dual Inlets 3/8 inlets,
$1,202 Step #10 Coolers & Accessories;
Front Mount;
$799 Radiator
CBR 31x14x2.25 dual pass w/ dual elec spal fans and mount, set for surge tank
$85 aluminum Brushed Surge tank/Overflow
Transmision**Suggest Dual pass
$250 Derale Pass aluminum Cooler
$68 S&H coolers
$2,296 Step #11. Wiring and Electrical
Includes; Autometer Sport Comp 2/16, Coolant Temp, Oil Pressure, Volt
$950 Wiring supplies W/Head Lights (Does not include top light/s or Rock Lights, Please choose Head Lights )
Master kill switch, optima Red top, wire, connectors, switch’s ( ignition switch, fan Switch, Toggle for lights {head lights and Rock Lights) clamps, heat shrink, wire ties, relays, fuse block, battery cables, grounds, circuit breakers, fuses, extra wiring for head lights and rock lights etc…..
ADD Trans gauge $64
Add Tach 3 3/8
$100 ADD Tail light wiring and Lights
**Turn signal
Lights
$132 qty4 –led rock light strips round eyes (under car)
Mikes Import spot LED Light Bar
$150 2x2” Dually Head light pair
**KC dot square
$550 36” E Series FRNT or top light
$350 mounted in light bar Craddle (protect for roll over)
$0 Step #12. Race Kit Options
TBD
$8,500 STEP #13. Motors;
STEP #16. Motors;
JIMMY'S "NEW GM" KIT;
GM Assembled long block Motors, GM Intake, DBW T-Body, F-body pan, Front kit with Hi- Mount Alternator, no steering pump, GM DBW Engine wiring Harness with Computer, Air Filter, pre & post Fuel Filters, Fuel Pump, Headers, starter, all Hardware…….
LS3 430HP $8,500
$2950 STEP #14. Transmissions/Kit;
$2950 THM400 HD/Race “B” 203 Short shaft Deep Pan
Thm400 “K” case*, Drilled for ¼” vent w/Barb, Short NP 203 output shaft, Billet HD converter, pump modifications, Direct clutch Drum w/32 Element Sprag, OEM Stock FWD Drum, New OEM Deep Pan, All plastic washers Removed, Transgo shift Kit or TG Full manual kit FWD shift kit, Winters rev FM No Comp-Breaking, locking dipstick, AN Fittings at case, and Gate Shifter
$2985 STEP #15. Transfercase; No speedo, Regular yokes
$2650 Atlas II with 32 spline front output
$225 Atlas Thm 350-400 adapter
$110 Shipping on Transfercases
$1,589 STEP #16. Plumbing Kit;
Base; just enough to do a base car, no Oil cooler, no Accumulator, no brake switch or line locks, no cutting brakes
Standard Race; Has enough to do a base car, but also will have a Oil cooler, and a oil Accumulator, with brake switch and a line locks, still no cutting brakes
**This price includes Fittings and ends for running brake lights and line lock, but does not include the fittings, Check valve for a Oil Cooler/accumulator, when Running this Items you will have more 30, 45,60, 90, 120, 150, and 180 Degree Fittings which cost more.
They are priced in the engine section..
Pure race; is the same as a Stanard race but is with Twsit Lock instead of puch lock
$1268 Standard Race PLUMBING KIT— 8600 Push Lock, Race kit KOH certified
AN fittings, series 8600 hose
ALL HOSES AND FITTINGS FOR;
BRAKES;
MASTER CYLINDER to Calipers, Cutting Brakes
FUEL-
INTAKE-REGULATOR-RETURN, VENT W/FILTER ,
Fuel length vent line to Catch can, over flow, or cap
3Add pressure port for rear Brake Light and Valve for Line Lock/Parking brake (KOH)
SHUT OFF VALVES (3 required for Hammer King rules)
ADD Fragola Billet
Radiator Plumbing kit;
-16 push lock and 8600 hose (Radiators must have AN fittings and Motor also)
$225 Rear Radiator w/Front mount engine (series 1-2 and 3)
$19,324 set/pair 2014 sheet
$11,742 Standard Mild steel Ultimate SPIDER 9 Front
Axle Housings & Knuckles
(Hi-9 and Driver Drop suggested for Front axles)
FRONT 3.5 OD x .25 Housing
3.5 x .25, ULTIMATE 60 KNUCKLE KIT, Ultimate1-TON UNIT BEARING, 5-6 LUG with 1/2 studs, Housing is cut and Knuckles are placed and welded,
Tube Seals
Tube seal ¼ tube and 3/8 Tube, Pair, single seal in each Housing
14” Brake kits for Spidertrax Knuckles
(qty 2 Hats, qty 2 Rotors, qty 2 wildwood Caliper 4 or 6 piston, pair wildwood poly matrix pads, and pair Caliper mounts)
4-piston kit
DROP OUT”S (Third Members)
(All carriers priced w/35spline and full steel spools, Solid spacer and 1350 forged yoke)
TRUE HI 9
Standard Hi 9
HARD PARTS
Steering arms for Spidertrax Knuckles
SPIDERTRAX STEERING ARMS BOLT ON
Axle Shafts (Includes S&H and assembly)
SPIDERTRAX 4340 axle shaft kit w/Yukon super U-Joints
Assembly Labor
Install all Drop outs shafts and install/Bolt on Knuckles and wheel hubs
ALL OPTIONS;
Unit Bearing and Knuckle options
$500-option Add Pro series Knuckles to Standard 3.5” Housing
$22-option ADD Extra axle seal, pair, to Double up in seal housing
14” Brake Options
DROP OUT”S (Third Members) Options
10” Gear works Housing Low Pinion,
$1300-Option ADD Gear works HI-10” gears, GW or MW spool 35-40 spline
LOCKER CHANGES
$730-option ADD SPOOL TO ARB 35 spline only
HARD PARTS
$250-option JIMMYS WELD ON STEERING ARMS, Double shear
$500-option SPIDERTRAX 300M axle shaft kit w/Yukon super U-Joints
$7,582 SPIDER 9 REAR
HOUSINGS
REAR 3.5” OD X .25 HOUSING
3” X .375 or 3.5” X .25 HOUSING, 1 Ton Full Floater End Cup’s, Ultimate 1-TON UNIT BEARING, 5-6 LUG with 1/2 studs, Housing is cut and End Cup’s are placed and welded,
Tube Seals
14” Brake kits for Spidertrax Unit bearings and end cups
4-piston kit
AXLE SHAFTS FULL FLOAT
Yukon “N” Iron housing 3.25, iron pinion support, Detroit, 28
Assembly Labor
ALL OPTIONS;
Unit Bearing options
14” Brake Options
LOCKER CHANGES
HARD PARTS
$300-option ADD SPIDERTRAX 300M axle shaft kit
$3,468 Step #18. Wheels and Tires
Wheels & Tires
$2100 BFG Red 39" Krawler set of 4
$1320 Fuel Beadlock set of 4
Lug nut kits
$48 Lug nut kits standard 6-lug acorn open 5/8
$13,585 Step #19B. Turnkey Finishing work;
All Projects are Built With set up parts. During the building process cars will be tore down and put back together numerous amounts of times.
Our goal is to keep your new parts as new looking as Possible through the build process.
We try to use as many “Mok up” parts and supplies as possible.
We use bolts w/Non locking nuts, No washers, they are not used in the build process so at the time of “Final assembly” the Bolts and nuts used on the project will retain there true locking function.
All Builds, from a roller to a full turnkey are tore down for final welding of Chassis and Mounts, there is no charge to pick up Chassis and Parts Un-assembled.
If you would like your “Build” in a Roller or if you are going full Turnkey, please pick on of the following Mechanical charges)
Base Builds;
Turnkeys that are Raw or spray painted, Base parts. No extra coolers w/ fans on accessories, base gauges, and Basic Plumbing. no lights
Standard Builds;
Standard builds are Projects that will get tore completely down and Transported for Powder coating of chassis and Mounts. Most usually will have a 8x10 Trans Cooler with electric fan and a log style steering cooler, no Oil coolers, No Accumulator’s, no race accessories or Comunication's, minor lights, etc…
expext extra accessories time to time
RACE Builds;
RACE builds are Projects that are fully loaded, extra cooling, Item's to pass race Tech, larger fuel tank's, remote fill, full light packages, race accessories and Comunication's along with GPS and Air pumper
PURE-RACE Build Turnkey w/Full Lights --Powder chassis
Includes, Installing All Hard Parts; Mounting all standard Base Build parts, Standrad and Race items. accessories
$10,000-+ Turnkey Package’s Non Paint
**Mechaical can change with Add's
**Paint and powder coat Prices are not Exact but Average cost of out last 10 Builds** For Estimate Only
$1785 Powder Coat
Chassis, small parts (radiator mounts, engine mounts, trans-mount, all clamps and Brackets, window net hardware) axle housings/Knuckles/diff cover
$1800 Body Paint/PC
Paint outer body hood, cowl, fenders and grille, Powder coat all interior panels
$2,800 STEP #20. Supplies
Bolt kit's, Grade 8, Nylon or steel lock nuts
$750 Bolt kit, Turnkey/Race
$550 Fluids/Race
Antifreeze w/Distilled water, Wilwood Brake Fluid 600+, GM Steering Fluid, MAG-1 Transmission fluid Type-F, MOBIL-1 Engine oil, REDLINE 250-Shock prof Gear Lube for both Differentials
Supplies;
Welding supplies, Grinding discs, Helmet lenses, Rags, Lubes and Cleaners, waste disposal, ETC
$1500 Turnkey/Race
$108,745 Total build costs plus Bronco Body, paint , new wheels and tires, upgraded storage, seats etc!
Financing available and we accept credit cards! Call or text 208-716-3244 for more details or come down to Harper Motorsports and check it out! WE SHIP TOYS NATIONWIDE! ANY ACCESSORIES CAN BE ADDED TO OUR TOYS AND WE OFFER WARRANTIES!
7168 N Government Way Dalton Gardens ID 83815
Harper-Motorsports.com
We are open Monday-Tuesday by APPOINTMENT ONLY
Open Wednesday - Saturday 10:00am-5:00pm
Closed Sunday
If you would like to make an appt to see one of our toys please call to set it up. We are very flexible and happy to meet any day!
