For Sale: NC
2003 TJ build recently completed. It`s been out wheeling several times mostly to test and dial everything in looks like no stopping from going to where you want. NO RUST. This Jeeep runs great around town, Not recommended for interstate. Better off -road; Barley Street Legal, drives straight, and no wobble. Here are some highlights: New Axles;Currie high pinion 44 front, Currie high pinion 60 rear both with ARB lockers and 4.88 gears, 1350 drive shafts and SYE. Four Wheel disc brakes. New 2.25 shocks and triple rate springs on long arm lift. Tummy tuck with flush skid. custom transmission crossmember and oil pan skid. One inch body/engine lift with new high clearance heavy duty body mounts, New high clearance gas tank. Upgraded roll cage,center console and steering wheel. This jeep comes with Full and half doors Bimi top, hard and soft top.It has new 37"X 12.5 X 15" BF Goodrich with/ W with Fuel Off Road D100 Zephyr Beadlock glass red (5X5) Center. Currie High Pinion DNA 60 REAR, Currie High Pinion Dana 44 Pinion Front Axle,4.88 geard and ARB locker front and rear, Adams front Driveshaft(1350) Rear Drivershaft slip Yoke Eliminator Kit, Tom Woods Transfer Case rear 1350 CV yoke,Tom Woods flange CV 1350 rear driveshaft, ARB diff breather kit, Currie Balljoints,ARB Onboard Air Compressor, JKS front Sway Bar Quick Disconnects,Currie Currectlync Steering system,Fox Steering Damper, Timken Front Unit Bearings, Custom Front Trackbar 2.5" OD with 7/8" heims.Custom Front Trackbar Chassis Mount (double shear) from Barnes 4x4. JKS Rear Trackbar and Mount,RC Seatcovers, Rock Crawlerz Bumper, Rampage Framless Top, JCR Crusader Trail Doord(Stock Full Doors also included) Accessory Switches to control air compressor and lockers, Poison Spyder HighLine Fenders,Poison Spyder Rear Body Armor,Truck Lite LED Headlights and Round LED Taillights. Smittybilt Winch, Bed Rug Carpet, Rock Sliders, Poison Spyder HighLine Fenders, Rock Sliders, Gen Right EXT 19.5 Gal High clearance gas tank and skid. GenRight 1" Motor Lift, GenRight weld-in Body Mount Lift Kit,GenRight TJ Belly Up Skid Plate-Steel,GenRight Universal Transmission Crossmember Kit, GenRight Aluminum Dash Panel Blank, GenRight quick disconnect steering wheel hub and PRP steering wheel,Novak Conversions Adjustable Cable Style Transfer-Case Shifter Linkage, Rock Krawler RRD 2.25 Shocks,Rock Krawler Springs, Poison Spyder Rear spreader bar kit for roll cage,Tuffy Center Councel, M.O.R.E. oil pan and transmission skid steering box brace, Scosche Base Clamp 9" Panoramic rear view mirror, Grade 8 rear control arm bolt kit,GenRight License plate rear mounting plate, Stainless steel rear Brake lines, Energy Suspension 2-6108R Rear Coil Spring Isolators, Metalcloak Universal Adjustable Bump-Stop System. Modifed swing away spare tire mount with off road Jack mounted to it also. Option for Buyer to purchase off raod garmin gps with rear mount camera.
