SOLD: Oregon 2000 TJ LS 6.0 Atlas TH400 Tons on 42" Treps
LQ9 6.0 Engine – stage 2 cam - 500 HP with 328 RWHP – Professionally Tuned @ PRE in Portland Oregon – HP tuner documented paper work
Turbo 400 Transmission with manual valve body and extra quart pan and trans cooler
Aluminum custom radiator with same side hoses for cleaner engine bay
Sand Hollow Offroad “SHO” shifter for selectable “oh shit” revers or neutral pin lockout
Atlas 2 spd Transfer Case
TMR Tcase Cross member with rear housing support
Dana 60 King Pin front axle
Front Detroit Locker 5:38 gears
Chromoly Shafts
Nitro Wheel Ujoints
Artec Truss and Ram Mount
AFW “Keyed” High Steer arms
Solid “Keyed” Knuckles
New Steering Links with heims
Complete King Pin Rebuild both sides with new Yukon Grizzly Locker and slugs
New inner and outer front hub bearings and seals
replace spindle bearing with nylon bushing
Crush sleeve eliminator kit
14 Bolt full float rear axle with disc brake conversion
Rear Spool 5:38 gears
New Pinion bearing
Axle Seals and bearings
Shaved 14 bolt housing
1.25” Heim joints on every link top and bottom – 16 total
13 bolt Crane Diff cover
Pinion Guard
Weld in tie down mounts for fast and easy trailer tie down
New Wheel Studs for the hell of it
Rear high mount brake, turn and strobe lights
Driveline Tech 188 wall double cardan front and rear drivelines
Custom 4 link Fr and Rear
14" ORI Struts with Piggyback reservoirs in all corners – new seals, polished shafts and custom drilled “4 Hole” by Jensen Bros for great performance
42" Maxxis Trepadors
17" Trail Ready Beadlocks
Corbeau Vinyl Baja SS seats
Warn 12 K Winch with wireless remote and wired controller
PSC 1405X pump
Large PSC reservoir
Derale 16" cooler with fan
Installed -12 and -8 lines
PSC double ended ram 8"
20 Gallon Fuel Cell with Aeromotive 1000 HP capable pump
Motobilt Fuel Cell mounts
Axles Powder Coated with Zinc Primer base with 1st color Alien Silver with Shocker Yellow top coat.
Rear Moto Bilt Alien Silver with Intense Blue
Straight true dual exhaust
Chromoly Shafts
Nitro Wheel Ujoints
New Pinion bearing
Pinion Guard
PSC 1405X pump
Large PSC reservoir
Interested in your Jeep, what's the asking price?
Chromoly Shafts
Nitro Wheel Ujoints
New Pinion bearing
Pinion Guard
PSC 1405X pump
Large PSC reservoir
I am interested. One post looked as if you are selling for 30k. Dismn@comcast.net. Cris
