SOLD: Utah / 2021 Custom Buggy
2021 Rock Lizard Sin City rolling chassis for sale, started this project in 2020 but unfortunately it is time to move on due to not having enough time or ambition to finish the project. Pretty much every part comes with the vehicle to finish the project except axle shafts and a carrier bearing. Also, there are many extra parts that you’ll need for the trail. I’ll try to list everything but I’m sure I’ll forget something. Easiest to just come and look for yourself. Here are the nuts and bolts of the build.
2021 Rock Lizard Sin City Chassis, 1.75 Heims
Engine - 403 LS 2 Stroker engine, stage 2 comp cam thumper, competition eagle rotating assembly, 57lb injectors, lsx truck intake, 102 mm drive by wire throttle body, arp studs, internal baffle in oil pan, comp 1.72 roller rockers, double roller chain, high volume oil pump, fast billet fuel rail, MSD coils, wires, plugs.
Transmission – 4L80 build by monster trans, monster package, able to handle 750 hp, 1800-2200 stall converter
Transfer Case – Atlas Race Case, 1410 yokes, 3.8:1 ratio
Front axel – F250 Super Duty, F450 axles with 35 spline, ball joint eliminators, F350 unit bearings, willwood light break package, Yukon competition zip locker, 5:13 gears, TMR drive flanges, artec heavy diff cover
Rear Axle – 14 bolt, 5:13 gears with spool, Yukon 27 spline chrome only shafts, artec heavy diff cover
Shocks – fox 2.5 coil overs with internal bypass, shelf adjust switch, upper and lower springs, 18” travel
Steering – PSC 2.75 x 8”, orbital valve, remote reservoir, fluid, tie rod links, mounting brackets
Wheels/ Tires – TMR 17 inch bead locks, TSL SX 43x14.50 Stickies
Virtually everything on this is brand new. Various extras in pictures from fuel tank, radiator, fans, plumbing lines, AN fitting, 10,000 lbs winch, side panels, lower boat skid plates, PRP seats with harnesses. Steering wheel, wiring harness, oil cooler, trasn cooler, ect
We do not need help selling this, this project will not be parted out, comes as is
Thanks for looking
Call or text 414 six one four 5586
my apologies, wasn't sure if we were allowed to say price, current asking is $50,000 OBO
thanks for looking!
Thanks for looking
how much
