For Sale: Utah, USA - 98 Jeep Cherokee
‘98 Jeep Cherokee - Located in Salt Lake City, Utah - Call/Text Kenny at 760 684 5766
If you are building a Cherokee, this XJ will give you almost everything you need.
Motor and trans are in great shape, always up to date on maintenance.
The body is kind of beat, it was a crawler, but as a donor vehicle to a cherokee project this will save you tons of time and money
The only hold up is that the Tcase needs serviced so this will need trailered.
I have more pics upon request but they were too big to post here
4.0 Motor
  • Dodge Neon Injectors (4 holes for better atomization)
  • Recent Tune up
  • New headers, larger downtube without the indent, cat convertor, and muffler
  • New Aluminum radiator, new coolant hoses, newish water pump
  • New Valve Cover
  • New Fuel Pump
  • Custom cowl air intake with K&N filter
  • Aftermarket Motor Mounts
AW4
  • New Trans Cooler
  • New Filter
  • New Mopar Neutral Safety Switch
  • New connections for trans lines into trans
Transfer Case
  • Durango parts inside, 6 gear planetary, larger shift fork, larger width chain, larger drive gears
  • Just installed master rebuild kit BUT upon test drive it clunks and in 4wd it ceases a bit - only took around the block once, inside should be fine but needs opened and redone before fully running
  • Aftermarket shift linkage since stock setup is terrible
  • Beefy StinkyFab Bellypan and TCase skid
  • Slip Yoke Eliminator and longer rear drive shaft - Aftermarket TCase mount (StinkyFab)
Suspension
  • Short arms
  • Rustys coils, Rubicon Express Leaves - Sits at 4.5 inches of lift
  • Iron Rock Offroad track bar and frame mount
  • Progressive bumpstops to limit rubbing
Axles
  • Ford 8.8 Rear with disc brakes
— Detroit Locker, 4.88 gears, Iron rock offroad truss, flange adapter
  • Dana 30
— Eaton Elocker, 4.88 gears, chromoly shafts, The housing is not trussed but also not bent at all
  • Replaced Ball joints within 10k miles
Steering
  • 1 ton heim steering kit
  • Durango steering box
  • Steering box stiffener
Other stuff
  • 52 in curved lightbar, small pod on each mirror
  • sitting on Dick Cepek Extreme Country 35s, still have tread but they are old, I would suggest them be rollers
  • Smittybilt XRC front and rear bumper set
  • Smittybilt Winch 12k lbs
  • Gas can
  • Frame stiffeners welded in
