For Sale: 2017 jimmys podium chassis
Status
Not open for further replies.
17 jimmys bloodline podium 1 3/4”chassis Candy red powder coated
Ls3 525 with hot cam, Holley throttle body
Holley dominator EFI ECU. Ron Davis radiator with duel 16” spall fans. CBR 12” fan oil cooler.
Monster heavy duty th400 transmission with Hughes 2200 stall converter. CBR duel 10” fan oil cooler. Two races on trans
2.0 Atlas transfer case with 1350 yokes
Torq super 14 drop out 3rd members. Spooled with 538 gears
Front
Torq built housing with D60s knuckles with solid industries 8-6.5 hubs. Willwood brakes. RCV 300m 35 spline custom shafts with CV
Rear
Torq built housing with solid industries D60 spindles and 8-6.5 hubs. Willwood brakes. RCV 300m 35 spline custom shafts. East bay drive lines. 1350’s
32 gal custom fuel safe fuel cell with duel in tank pumps. Yellow foam. All new setup before KOH19.
Warn 9000lb winch with 100ft of nylon winch rope. New rope KOH19.
Prp seats, harnesses and window nets
60w Rugged radio and intercom
Rugged duel pumper, all new KOH19
Safe craft fire suppression system
PAC sway bar, arms and links
Fk rod ends on links and tie rods
Psc pump and 1 piece ram
KC light bar, 4-2” KC cube lights. rock lights and work lights under hood and above fuel cell
17” raceline beadlock wheels.
Tires and suspension can be set up for 4400 or 4800.
4400
40” Yokohama m\t’s
2.0 rad flow coil overs
2.5 rad flow bypass
14” on front
16” on rear
2.0 fox bumps
4800
37” Yokohama m/t’s
3.0” fox ibp coil overs
14” on front
16” on rear
2.0 fox bumps
Spare parts
10 8-6.5 raceline wheels
1 set of front rcv 300m axles
2 sets of rear rcv 300m axles
3 sets of drivlines
Small misc parts like inner axle seals, king pin parts, hub pucks, wheel studs and bunch of other little stuff.
Finished 8th in 4800 class KOH19
This car has only been in 5 races and has finished all of them. 60k
Status
